Our 2005 Monaco Knight has a 50amp system with a Magnum ME2012 inverter/charger and 4 200ah 6v deep cycle batteries. We are replacing it with a Victron MultiPlus-II hybrid inverter/charger and 4 208ah SOK2 lithium batteries.
Problem -- We have the expected 4-line 50amp shore power cable going to the transfer switch, but the line in to the Magnum inverter from the transfer switch only has one leg. They installed a jumper in the inverter Line In from line 1 to line 2 to make both legs hot.
So, instead of 2 120v hot lines coming in, it is just one hot line jumped.
The output from the Magnum inverter is the expected 4-line to the breaker panel.
Question -- Is it common to have 3-wires coming into a 50amp inverter and jumping line 1 to line 2 a common practice?
Question -- Can I use this same line in jumper with the new Victron inverter?
Thanks in advance,
Mike and Deb Fry
2005 Monaco Knight 38PDQ and 2015 Honda CRV
Thanks in advance,
Mike and Deb Fry
