I am starting to work out my plans for moving batteries (currently lead acid stored in an outside compartment) and installing a Victron Multiplus 3000 inside the RV. (2016 Thor ACE 27.1) The most logical space is under the Dinette. Most all the electrical is there anyway. I will have to remove some blocking that is protecting some heater vents. to open the area up a bit but it is still pretty tight. The Multiplus will have to be installed horizontally which I have seen in some van builds. Im not sure I would have the recommended 10cm clearance.
The area that will house 2 - DIY 280AH 12V Batteries, Multiplus, SCC, Buss Bars and fuses ect. is approximatly 14-1/4" tall x 17-1/4" wide x 51" long.
Multiplus 3000 is 14.3"x10.2"x8.6"
I am worried about heat build up in such a tight area and the Multiplus not being vertical. Would love some insight about my plan. I have a couple other questions but I will keep researching them before I ask. I attached some pictures to help.
Thank you.
Thank you.
