Hello all, I'm a new user to the forum and been reading for a few weeks trying to learn about diy batteries and Victron equipment. I installed a Victron Multiplus 2 2x120 in my 5th wheel this week. I have the Victron Power In (I thought I was ordering the DC distribution), but it appeared the only difference was the ability to monitor it on the Victron network, and the missing bolts to hold the fuses. I put in my own bolts and connected batteries and MP2 and that seems to be working okay. I don't have a smart shunt, but I put VenusOs on a Raspberry Pi3 and installed the dbus-serialbattery drivers to use as my battery monitor. This all seems to be working.
I have a 2P4S configuration of EVE 280ah cells using JDB 150a BMS, one for each 4 cells. I top balanced them a few weeks ago and they have been sitting until I received and installed the equipment. I don't yet have solar, so I am just charging with 30amp shore power or my Honda eu2200i generator for now. When I first hooked up the batteries, I connected to 1 bank and let the MP2 charge, then I connected to the other bank, let it charge, then I put them in parallel. I guess didn't wait long enough with them resting to check the voltage, so they are off by about .17V between the banks. Within each battery the cells are only .05 off roughly. All cables are pretty short and mostly even length. The one exception is the pos cable from the battery to the Power In is maybe 6" longer than the neg cable.
So life is good, until I try to charge. I set Absorption to 14.2v, Float to 13.6 and Absorption time to 1 hour. I turn on MP2 and it starts at Bulk. When it gets to around 13.5v it goes into Absorb, and it stays there putting in around 5amps and tapers off to 0. The voltage never got above 13.65 I see in most discussions that Absorb should be really short. I found one post that described this was the point the BMS was balancing and it seems their suggestion was long was okay with low current in. So I let it stay in absorb almost 12 hours yesterday. It never stopped charging in absorb. After about 7 hours, I turned on all my 12v lights for about 30 minutes and it dropped the voltage to 13.26 and then went back to Bulk. After about 30 minutes it was back to Absorb. This time it went up to 13.8v until I shut everything down overnight.
So what am I missing? Is the .17V difference between the banks causing this? dbus-serialbattery can only show 1 bank to the victron as a battery monitor, and it is using the one that it thinks is most charged. I'm trying to get some help from the vendor I purchased from, but so far they are busy and no return calls.
What should I check or change? Thanks for the help.
Jeff
Jeff
