Hello,
I'm looking to setup a small solar/battery system for a few circuits in my home (US). I'm only looking initially to run a few lights and internet router/WiFi, and have the option to run my fridge and/or freezer overnight during a power outage. I currently have an 8 circuit manual generator transfer switch that I can switch individual circuits from "gen" to "normal". I'd like to get an inverter/charger to feed this transfer switch with. However, my requirements are UL 1741 listed and the ability to remove the neutral/ground bond from the Inverter (since my panel already has a n/g bond).
These requirements leave me with Victron and Samlex as the only (reasonably priced) options. I realize the MPP Solar also has an option that is a 48v model. I'd like to go Victron for all the integration and connectivity ability. However, Victron appears to be almost entirely geared toward RV/Marine. Their UL listed options are also currently limited to just the 3000VA 12v & 24v multiplus models.
Is anyone here already doing the same and what's your experience?
On a side note, I already have (1) 100AH Battleborn battery. Because of this, I'd like to stay 12v (in order to avoid the cost of buying more batteries up front to go 24v or 48v equipment. However, how do these reputable companies endorse the safety of pushing surge wattage of 6000W thru a 12v system? Can the BMS' in 12V batteries even handle that many amps? (I'm thinking I would have to parallel several batteries to support that kind of surge?)
Thanks,
Jeff
Thanks,
Jeff
