Impossible.
14.6V * 25A = 365W
You expect to get 12V * 50A = 600W
You can't get 600W of power out of 365W of input.
Thank you so much. Just learning about these devices. I bought one not knowing what all it is capable of obliviously. Sorry for all the questions. Read the manual and cannot figure out a few things.
I think it is great that it shows up in the remote admin console pages.
Strange that it does not in the VRM interface.
So it is a step-up converter, but only sometimes when the voltage difference is greater than it is right now, and not many amps?
If I have the alternator output at 14.6 VDC and 25A going INTO the Orion XS, on the output side the battery it is trying to charge is at 12.6VDC (2 volts less), I should never expect the output amps to exceed about 26A?
I don't know why I thought it was a step-up converter. I thought it had some sort of CC/CV in it. It sounds to me like it will only charge the battery at or near 50A *if* the Orion's input receives 50A. Is this correct?
If this is all correct, or close to correct, then I now know why sometimes people attach 2 of these devices to their system to push more amps to their house batteries as they drive in a RV/Camper.
Next, I believe the purpose of this device is to safely charge lithium or other chemistry batteries from the vehicle's alternator, because if you just connected the output directly from the alternator without this device (pushing all the amps it could into the house batteries) it would not know when to stop charging safely, which is what this device primarily does - safely charges a house battery.
Also, if my RV's 12V 200Ah house battery was at 10% SOC, but I could only charge at 25A with the Orion XS while driving down the road, it would take about 7 hours 25 minutes to charge back to 100%. If I had 2 orions at that same 25A rate, it would take about 3 hours and 35 minutes to charge. I like that better.
Finally, does the solar typically charge the house battery while driving, too? The MPPT is just left on and hopefully there's some sun at the right angle while driving between campgrounds?
Screenshots of VRM Dashboard and Remote Admin Console (venus GUI v2)
