It appears in order be code compliant in a residential install in the USA, any SCC from Victron appears to require you to purchase an external Ground Fault Protection Device. Is this true? I was specifically looking at the SmartSolar 250/70 and don't see anything related to arc fault or ground fault protection built-in. If this is true this adds considerable amount of cost to this solution.
Was looking at Victron because of all their networking and easy integration with other systems (their protocol is open source for communication with it so even the Chargery BMS can tell it to turn charging/loads off).
