ricardocello
Watching and Learning
With higher string voltages (> 250v), multiple runs of smaller wire tend to make more sense.You both have got me thinking now, however Im going to be adding more strings down the road. I haven't checked the chart yet to see what ga I need with my new found limitations on the SCCs. Will probably be adding another 450/200 down the road also and reconfigure my strings to best output. Will still probably be close to 7 string.
With lower string voltages (< 250v), bigger wire is a better match for the charge controllers.
I regularly run 33A @ 165V into my MPPT 250/100 (and get the full 100A out).
Can’t do that with the 450/100.
It is a tradeoff between future expansion plans, voltage drop, and best match to the solar charge controllers.
And the number of trackers you need. I’ve got shading to deal with, so I like the parallel strings.
