Here is what I have and trying to figure out what the best settings are for my setup. I will keep this short but I have a bassboat that has 4 batteries, 1 agm starting battery Interstate 31M-AGM - https://www.interstatebatteries.com/products/31m-agm (also runs a few loads basically livewells and some lights) and then three LifePo4 batteries all Powerurus 100ah batteries, one for house that runs all electronics and 2 are for the trolling motor. I am unable to store my boat at my house for several reasons but the main reason is that I am on a hill and its just a royal PIA to park so to get around not having it at my house I need a way to keep the batteries charged. I have several electronic devices that "combine" the starting batteries and the house and trolling batteries. I've had these for years in my older boat and they work pretty well for the most part, when voltage reaches a certain level on the starting battery it places the other batteries in parallel so the alternator in the engine charges all the batteries. If anyone is interested here are the devices that I am using, they are called combiners from smart shore marine, previously Yandina - https://smartshoremarine.com/products/battery-combiner-100-for-lithium-batteries and then for the trolling batteries - https://smartshoremarine.com/products/trollbridge-12x24-for-lithium-batteries
This works pretty well for the most part, as long as I am running the main engine all the batteries receive a charge and the newer engines even at idle put out a lot of amps. There are a few lakes that are trolling motor only lakes and when fishing one of them since I am unable to run the main engine I am unable to keep the batteries topped up. On board I have a 25amp victron charger single output marine smart IP67 charger - https://www.amazon.com/Victron-Energy-12-Volt-Battery-Bluetooth/dp/B07TMRJQTH but trying to figure out how to get it dialed in. Currently I have it connected to the starting AGM battery which once the voltage reaches the set level combines with the other batteries. The problem I am having is what settings I should use on the victron. I found out when charging and balancing my Powerurus batteries that they would not go over 14v when balanced so I had set the voltage on the victron to 14v but it appears that once the agm battery is hitting 14v it moves from bulk to absorption and then to float before the other LifePo4 batteries reach full charge. I am thinking of moving the victron leads to the house battery since that is usually the battery that is the lowest but I am also thinking that maybe I need to increase the voltage to 14.1 or 14.2 and/or setting the absorption time longer so it keeps the voltage set for a longer time. The other option is to just set the victron in power supply mode and set it to 14.1 volts.
I guess my question is when I have a combination of batteries what kind of charge profile should I use, I understand that I am wanting to charge the LifePo4 batteries over the agm and that it probably wants a higher voltage but it is what it is with my setup. Would putting the victron in power supply mode be the best way to get all the lithium batteries to get close to full?
Looking for any suggestions on how to optimize, @sunshine_eggo or anyone have any thoughts?
