sunshine_eggo
Happy Breffast!
Depends on battery type and manufacturer. 0.1C (10% of Ah in amps) is always safe. Some AGM may be happy at 0.2C and some even at 0.3C.
0.1C of 390Ah = 39A; 39A * 14.4V = 562W
0.2C of 390Ah = 78A; 78A * 14.4V = 1124W
15A max out of a single 360W (and you say MULTIPLE) panel(s) suggests you may be using 24V panels on a cheap PWM controller. PWM controllers work by shorting the panels to the battery. This forces the panel voltage to battery votage and likely cuts the POSSIBLE power output to 50%.
I'm not at all convinced new panels and new MPPT will fix your problem until we find out why you're not getting more than 15A out of your existing setup.
