I have a victron smart shunt that is no longer showing correct voltage or wattage but is still calculating correct SOC and Amperage. I am at a loss for how to troubleshoot this issue. Please share any ideas for the cause or ways to troubleshoot. Thanks!
Some background...we recently upgraded our off-grid lithium battery bank to EG4 batteries. The smart shunt worked as expected for over a month with the new batteries then the voltage reading dropped to between 0.06v and 0.08v depending on state of charge. Wattage is no longer being calculated but Current, Consumed Ah, and SOC are all readying correct. I have disconnected the shunt and reset setting but still have the same issue. See attached images of the readings at 69% SOC and 100%.
