What is VictronConnect?VictronConnect does let you make such settings but I don't know if the battery protect actually works that way. You might want to asking this on the Victron community forum at https://community.victronenergy.com/
Just want to confirm before I purchase that you can set the disconnect to 27.06 and the re-connect to 26.15?VictronConnect does let you make such settings but I don't know if the battery protect actually works that way. You might want to asking this on the Victron community forum at https://community.victronenergy.com/
I saw that.
I bought one based on your advice.VictronConnect does let you make such settings but I don't know if the battery protect actually works that way. You might want to asking this on the Victron community forum at https://community.victronenergy.com/
My advice was to verify with Victron via their community forum. Did you get an answer there?I bought one based on your advice.
Turns out the user interface won't accept shutdown voltage greater than restart voltage.
"VictronConnect does let you make such settings but I don't know if the battery protect actually works that way."My advice was to verify with Victron via their community forum. Did you get an answer there?
When I run VictronConnect on my iPhone and go to the demo library for a battery protect, it does let me set a shutdown voltage great than the restart voltage. But as I stated, I don't know if a real battery protect actually works that way which is why I suggested verifying first with Victron.
With a normally closed ssr it does the job.Not a big deal.
I using it for another purpose now.
