AgentOneee
Hi there,
I got two brand new Victron Smart Lithium Battery 25.6V 200ah and plan to connect them in series to build a 48V Victron off-grid system for my camper van. Based on the manual, I need to do an initial charge on each battery before connect them in series.
Initial charge:
I used a Victron blue smart charger ip65 connect to a Victron 12/24v 65A battery protect. The charger red cable connects to IN port while the OUT port connect to Victron BMS 500 and then BMS 500 to the battery. Similar to this attached diagram but charger instead of DC load. (See the attached diagram)
I tried 4 attempts of charging. Each attempt of the charge is using adsorption 28.4v, floating and storage 27.0V, adsorption time fixed 24hours. As long as the charger jumped to floating stage, I will manually disconnect the charger, wait for all lights off then reconnect.
During each charge, from cell 1 to cell 7 will stay at 3.51v to 3.52v while cell 8 will stay at 3.48v all time. I do see BMS turned on and off all the time. I know this is normal, however BMS and charger cut the power and reduces the current to <1 amp or even 0 amp. Is this mean the balancing is not active since it is less than 1.8 amp? is this because my battery is full so it can’t flow any current anymore?
In conclusion, no matter how many times I tried, the last cell always stay at 3.48v while other cells are 3.51-3.52v. I can’t get the battery fully charged to 28.4v. The BMS saying the SOC is 100% but the battery voltage stop at 28.1V. Does it suppose to reach 28.4v max as fully charged?
I contacted the battery distributor and they told me maybe the battery is not rebalancing enough and ask me to charge more.
My question: is there anything I did wrong? Is the battery behavior normal? Do I need to discharge the battery to 50% and then charge again? Or I should keep charging while it’s 100% SOC to let it balance.
Please help.
Initial charge:
Please help.
