Thanks
I did use that calculator before posting and it did not list the 100/50 for my application, it listed the 150/70 (which is twice the price around $600) and can charge a full 1,000 watts Into 12v battery. I get why victron would say that is the right match for my panel array because if cost were no object it would be.
The 100/50 at $300 seems to be perfect for me when it can do 700 watts into the 12v (and otherwise fits the voltage/amp ceilings) due to my intended application below. I’ll actually be getting two, each paired to 1 kw of panels, so roughly the same Lexie as one 150/70 doing 1kw I’ll have two 100/50 doing 1.4kw.
I’m interested if anyone thinks there’s a Better plan that reaches the intended specs:
- get full battery charge (5.75 kWh usable, lifepo4 12v 560ah) during all seasons (assuming a reasonably sunny day) in Texas
- beats $1,250 (panels and charge controllers) — no cheating, needs to use victron (or comparable top tier) charge controller
My Current Plan to meet Specs:
- 2 kw solar panels (8x250w) — $600
- two victron 100/50 - $650
- Two identical arrays of 2s2p 250w panels, the used 250w panels from santan solar that will prowae recently featured (I expect they’ll rarely be going over 70% output anyways)
- each string of 4 panels going into a Victron 100/50, so each 1 kw array can charge up to 700w, for 1.4 kw peak charge
- charging into a 12v 560ah battery bank (8 of the prismatic 280ah cells)
- battery bank usable 5.75 kilowatt hours (using cells in the recommended 10-90% depth of charge range)
- therefore needs about 4 hours per day of panels reaching 70% (1.4kw) of rated output to get full 5.75 kWh charge
I’m a newbie and overpaneling doesn’t have the greatest info out there compared to some other topics (eg search YouTube for ”over paneling solar” and there is not a lot...).
Thats what is awesome about this forum… I can do a ton of research so I’m not abusing peoples time, then double check my understanding here with some DIY experts so I don’t go frying expensive gear. Catching something on fire, or electrocuting myself
