I should have realized that. He had VRM!
Thanks
@740GLE for chiming in as well.
I have that:
but that is showing the combined performance of the array during the day for both of them charted by time of day - cool. But what I'm seeing is the total kWh produced, like this one at the bottom of the non-advanced, single day view:
The aggregate data - 9.8 kWh solar - and then I want to compare that number to other days.
See how in advanced you can see the aggregate number PER MPPT:
Imagine if you will a bar chart showing 9.8kWh today, 7.2kWh yesterday, etc based on day/time range, which you can sort of do here on the main dashboard (not advanced) by telling it a range (7 days), change it from 'system overview' to just 'solar' at the bottom?:
The problem comes when you want to do more than 30 days. Here is 30 days:
When last 90 days, instead of being like 30 days above, it aggregates each week, which I didn't ask for:
Furthermore, I didn't ask to see consumption at all - I just want the total, which you must hover over to see:
...which again I don't want to see direct use, and I don't want to hover and see a total for a week at a time, just a day, like the 30 day.
Pretty sure home automation software does or solar assistant or whatever. Thought this existed in cerbo gx land as well.
Here is the last 90 days with the PV Yeild:
Notice that it says only 1188 today, not accurate at all. Above you can see it hit 8x that today.
also, notice how if you have 30 days chosen, and you look at the charger summary, the charger summary doesn't have a yield total option, just today and yesterday. If it had something like average per day in range, or total in date range, or listed each of the 30 days total in a giant list that would be closer:
Bottom line is that if you have more than one MPPT, or just one, and you want to see 30, 90, 365 days plotted out, I can't find a way to do that. Something that simply displays the total amount yielded per day as tabular or bar chart data.
