Wow, the maestro himself! Thanks alot!Hi
It seems that the driver can either not read the cell count, or that the min max cell voltage setting has an issue.
Can you paste the values you have set for min and max cell voltages.
Also how did you make the edit? Did you change the file perhaps in Windows and copy the file it over to the GX? Windows use other line endings in files and this can sometimes cause and issue if you did a newline(Enter) in Windows editor. Try installing the driver again and then using the nano editor inside the GX system to make the same edits to see if that helps.
Actually I connected to the Pi with Linux Mint via Putty and then used the nano editor (took me quite some reading and learning the shortcuts).
Screenshot attached.
I spent weekends installing the driver, even complete Venus in different Versions over and over without any success. Tried every USB-port of the Pi etc. I'm afraid the 100th installation won't change anything.
