Hi gurus,
I have a twin 130AH lithium set up in my car. So 260AH. The batteries are for start up and auxiliary components. The BMS automatically cuts power use to ensure the car is always able to be started. Anyway….I’m running 53mm2 cable 6m from front to rear. Same cable pos and neg, Victron shunt near batteries, with a victron 220a BP at the rear. My 3000w inverter is connected straight to battery side of the BP in the rear cargo area. Upright dometic fridge and various battery chargers are plugged in full time.
The batteries /system is cabable of draining at 200AH. All the online charts I used state a 1v drop at 200A across that cable over the 6m. The inverter cuts out if volts drop to 10.5 v.
The issue I’m having is, I’m getting a 2v drop from batteries to the inverter at anything above 150amp draw. Cable should be sufficient based on charts although I am contemplating going to a 70mm2. But I’m not 💯 convinced this is the issue. So the inverter shuts down, hitting its 10.5v threshold, but battery Bluetooth and victron shunt confirm batteries are down to 12.6v at the 150a draw. So in my head the batteries have plenty more to give but the voltage drop is killing it…..
This makes my induction cooking and onboard coffee machine die…. So frustrating. 1st world problems I know, but there has to be a solution.
Thanks in advance
Robert
Thanks in advance
Robert
