I measure the voltage drop directly at the BMS between B- and P- with nothing else in between.
If I discharge less than about 7.7A from battery then the BMS have just 3 mV voltage drop between B- and P-.
If I discharge more than 7.7A then there is a voltage drop of 0.6V between B- and P-.
This looks to me that the MOSFET for some reason is not working properly.
I also see that when I discharge 10A the BMS display discharge of 36A so the Current and SOC is in complete error.
I use BmsMonitor V1.2.8 and I do not find any parameters that seems to be wrong.
Daly BMS 4S 12V 200A Lifepo4
R05W-GF24
SW version:20210520-3031A
HD version:DL-BMS-R05-01E
Daly support only answers irrelevant parameter changes and does not acknowledge the problem.
Anyone with the same bahavior or have a clue about the solution to the problem?
R05W-GF24
