woodwardable
Tom
I have four 12V 170 AH BigBattery batteries connected together in parallel, that are then being split into two outputs with a reversed parallel cable. One output runs directly into my RV while the other leads to a 100 amp Renogy solar charge controller (1200 watts of solar panels are connected), a 1,000 watt renogy inverter, and a battery monitor.
The inverter and charge controller continuously screech low voltage alarms, while the battery monitor and the batteries themselves (the batteries have a voltage monitor screen) say everything is fine. I turned off the solar charge controller alarm because I feel like the batteries are more accurate. I’m wondering why the charge controller and the inverter are inaccurate? Does it have to do with the fact that I split the batteries into two connections from the source? I also just installed the fourth battery recently. Maybe this could have something to do with it? Everything has been fine for the two months leading up to the fourth battery installation.
