Calothrix
I have a 10A max power supply that is also 30V max. I just discharged my 380Ah, 12V, 2P4S configured LiFePO4 battery and I am in the process of charging it with the power supply. I do not want to charge with any more than 6A, as I do not want to take a chance of burning out the power supply. However, in order to get it to charge at 6A, I have to set the voltage to over 15V. As the battery charges, the current coming from the power supply slowly falls. Is it OK to increase the voltage to keep the current around 6A? Is there a max voltage setting that I should not exceed in order to accomplish this? Basically, what I am asking, is it OK to crank up the voltage early in the charging process to speed things up a little bit and then once the battery is charged to about ~13.3V or so, turn the voltage of the power supply down and monitor closely until it is fully charged? Thanks!
