Equipment
16 EVE LiFePO4 304Ah
Victron MPPT 450/100
SmartShunt to measure current - 250A version
BMS is JK BMS - 150A max current model
Victron 48/5000
I am seeing my LiFePO4 bank voltage rise quickly with a charge current over about 40. I have MPPT absorption voltage at 55.3 with float 54.4. It happens regardless of the SOC - I first noticed it last week with a SOC of about 60. I experimented with it again today with a lower SOC (see graph below) and I am still seeing the voltage spike and then fall back to about previous as the cells "rest" for a minute or two.
The first (mobile) screenshot shows this phenomenon the best. The website screenshot was from today at the lower SOC- it is partly cloudy so I think it is a bit less clear on what is happening.
If you look closely you see amperage rise and shortly afterward voltage rises until the float voltage is reached. Float voltage on mobile screenshot I think may have been higher than the second screenshot - looks like its probably 55.4. (I know it is not any higher as I've never set it higher in the past)
Voltage reading reported correlates within a mV between inverter, bms, mppt etc - I don't think mppt is seeing an incorrect voltage.
I do feel the SOC is accurate as there is a constant load on the inverter and the consumption rate makes sense for the below SOC. It was recently "refreshed" with a full charge two days ago.
BMS is not hitting overvoltage or overcurrent cutoff - It is quite a bit higher for both.
I've noticed with a few tenths lower absorption voltage the bank will take a higher charge current but then things are cutting off before SOC is at 75% - I have node red reducing the charge rate when SOC hits 75%.
I don't think this is normal as this is less than 0.15C with these numbers. Any thoughts on what else to check?
xxxxxxxxxxx
Victron 48/5000
