wonderspark
Here comes the sun... it's alright.
I agree with starting over.
I noticed there were no ground bars in either panel, and they landed grounds and neutrals on the neutral bar, hence my thinking that it didn't matter where I landed the ground.
The transfer switch came with all the wires in the FMC pre-installed, and it was stuffed with the sets of wire for the hots, the neutral, and the ground. I knew I couldn't add more than a couple wires to that, so I added in my own second FMC to handle the added neutrals for the AFCI breakers. I then pulled all the wire out of the pre-wired FMC and started over, getting all the hots and neutrals for each panel into each FMC, so they'd be together, since some were going into the lighter left panel, and the rest into the right panel. So wire to left panel is in one FMC, wire to right panel is in other FMC. Both FMC are properly connected to the transfer switch on that end, but in the panel ends, they are just lying in there. That's my bad.
What I'm taking away here is that I started with panels that were possibly not 100% correctly installed, and added my own errors to it.
Given all this, and starting from scratch, I have a dilemma. There are only five open breaker slots on the right panel, but six in the left panel, so I can't move all of them into one panel, unless I did something like use some tandem breakers.
What is the best way forward here? Just undo it all and bring in a better electrician than the one that was hired by the builder, and tell him what my goal is? Or is this salvageable myself? I had wanted to get a second transfer switch to add more circuits, but seeing that I've jacked up the first ten myself, I'd like to get the system correct as it stands now.
