James Staples V
- Jul 20, 2021
- 19
The first things that knocks me down is Voltage . 12, 24 48 100 ?? How do i determine which will be best for the job?
I used 1920 mvh last month . As high as 3k in the winter [ last winter was an extreme - I hope] why would I want one voltage over another ??The first things that knocks me down is Voltage . 12, 24 48 100 ?? How do i determine which will be best for the job?
What is 1920 mvh? Do you mean 1920 KWh?I used 1920 mvh last month . As high as 3k in the winter [ last winter was an extreme - I hope] why would I want one voltage over another ??
Yay!!!Off-grid solar is the single most expensive form of electricity there is!
oops KWhWhat is 1920 mvh? Do you mean 1920 KWh?
You use that much power, 1920KWh, a month? That is a lot of power.oops KWh
I mean. I have used up to 1600 myself.You use that much power, 1920KWh, a month? That is a lot of power.
That is a lot, that will be $338 a month based on 26 Cent/KWh here in SF Bay area.I mean. I have used up to 1600 myself.
Typically I'm around 1300.
Yeah it does sound like alot . But, i am wanting to be sure i have excess power for back up in case the weather makes me use more watts than expected, and the sun is kinda not so bright . As soon as my Afib attack mellows out. [been flat down for the most part this week wondering if my son will have to begin my final wishes bullshit if I don't make it the rest of the way through my 30 day heart event monitor] I will dig up my room floor plans and room needs.I mean. I have used up to 1600 myself.
I know it is rediculously redundant, but I am thinking of getting a separate units for my fridge, hvac, dialysis machine, washer and dryer. so far i have whittled my usage to 1092 kwh per month. Hanging our clothes helps.
WWOOOOOow ! I thought prices sucked here !!! Can you tell me why i want a 12 vs 24 vs 48 or higher voltage ?? For the wattage and whatever else ??That is a lot, that will be $338 a month based on 26 Cent/KWh here in SF Bay area.
In general, For a given load, amps are (inversely) proportional to voltage.WWOOOOOow ! I thought prices sucked here !!! Can you tell me why i want a 12 vs 24 vs 48 or higher voltage ?? For the wattage and whatever else ??
