I have had a single 6000xp running my smallish loads that include a legacy AC that has a high starting load (approx 60amp at 240v). This single 6000xp has successfully started this 3 yr old AC and run it for 6 months here in South TX (running load for the legacy AC is about 2800W at 240V once the unit is started). I would notice that my Solar Assistant would show the 6000xp switching to the grid when the AC started. I figured that this was just an overload issue that happened randomly once or twice per day. The unit would always switch back to solar/battery in about 5 minutes without any drama. I figured that what I needed to do was get a second 6000xp to ensure no more W028 overloads.
Fast forward to today. A second 6000xp is installed in parallel with 300ah of shared LIFEP04 battery in lead acid mode. Not only do I get more W028 overloads, I get them continually once the batteries are fully charged to 56V and the solar goes into idling mode. This is happening with full sun and over 6000W of solar just waiting to be needed. If the battery is charging, the 2 - 6000xp are behaving as expected and share the solar between the battery charging and the AC running. I can fix this issue by turning off the solar and immediately, the AC is run off the full battery without any issues.
I know this is a known issue for the 6000xp and 12000xp ( @SomethingAppropriate @Barndo @EG4TechSolutionsTeam @Quattrohead @ChrisG @42OhmsPA ) especially with batteries integrated with communications cables and the fix has been suggested to move to lead acid mode. I want to report that the lead acid mode is not the answer in my situation. My inverters are set to have a 140A limit on discharge ADC. I will double this setting as I should be able to support 300A with the batteries. However this doesn't seem to prohibit the system when solar is turned off from fully utilizing the battery without switching to grid.
Both 6000xp are running latest firmware
Serial Numbers for inverters are 422374xxx and 3393741xxx
