Hello guys!
We are located in Europe, and building a motorhome. Currently I'm designing the electrical wiring for the mains 230V AC.
We will use a 24V / 230V 2kW inverter from battery, but when we have the possibility we would also use external AC. For the safe switching between the internal and external power, I designed a circuit, with the following points in mind:
- for external power, we plan to use the EU standard mains plug, because this is what we can find on most places in Europe
- the inverter and the external source is not allowed to be connected at the same time
- when the external power is used, we would like to automatically charge the motorhomes battery bank
- if the external power source has any faulty or abnormal wiring (eg. the order of the L, N, E is incorrect, or any of them is missing) the isolation relays should not engage
- the motrohome must have his own RCB and MCB, which we will use also for the inverter and external power
So I've came up with the following schematic, which I also built and tested for all the possible cases: it should work only if all 3 wires are present and all are in the correct order. Please take a look and tell your opinion.
For making things a bit more easy to follow:
0)
All the relays have small current coils (less than 6mV), so they will not trip any existing RCB (the lowest rated RCB on the market is 15mA, this coil uses 3 times less current)
1)
R7 is there for the case when the L and N are present and are in the correct order, but E is missing. In this case the current goes through both relays, K2 and K1. But because the current is weak, causes an abnormal functionality, sometimes engages the relays, sometimes not. For a safe function, if there is no earth, it must not engage K2, and must engage K1. R7 helps for both relays, in this aspect.
2)
K0 is used to completely isolate the external power, not only L and N, so if from any reason it is high voltage on the E line (faulty earth), it should not output on the whole vehicle. It is connected only if the external power has a safe ground
Thanks!
0)
1)
2)
Thanks!
