Hi all, need advice on high current demanded 25.6V 280AH battery bank for my boat bow thruster. The thruster motor is 24V and will pull up to 300A. My question is, should I build
a) one single 25.6V 280AH with 8 280AH cells in series and 400A BMS or
b) two 25.6V 140AH with 8 140AH cells in series and 200A BMS, and then connect them in parallel to install in boat?
Just want to know which option is better or safer for my case, thanks very much!
