Water Level Sight Tube - completely DARK, Why? ...drainback tank
CitroM
I am looking at a used AET drainback tank, 10 Gal, with a heat exchanger coil inside. The level sight tube is completely dark - so dark, I thought it was broken and replaced with a dark plastic tube. Seller says it's still glass and is "sediment" discoloration.
Anyone seen something like this? Possible cause?
Not uncommon in sight glasses. You should be able to pull the fittings off, get the tube out, then a thin bottle brush & soapy water should clean that right up.
Thanks Rednecktek!
My main concern is whether the dark deposit could be residue from melted/degraded PEX or acidified glycol.
If these tanks are known for this (dark deposits on the sight glass) in otherwise healthy systems, then cleaning should be relatively easy.
I appreciate you sharing your experience!
Michael
Redish deposits - often Iron
Black deposits - often manganese
remove and clean with chlorine bleach and a brush.
does this tank have an anode? I would check it's condition, see if needs replacement.
...good idea on the anode. I'll check once I have it in my shop.
I am encouraged by that the deposits are not more alarming than a cleaning issue. Thanks for the comment!
Tanks collect debris, it is a good idea to flush the tank a once or twice a year to a drain, to clear any debris before it accumulates too much.
You don't need to dump the entire volume, just flush from the drain valve until it runs clear.
I do my tanks on my B-Day each year, that is my reminder.
