Watt Cycle 12V 300Ah, Mini form factor battery?
Northman
USA
Hi all,
A couple questions on the above mentioned 300AH, "mini" battery from Watt Cycle, http://tiny.cc/g5t0001
1) Has anybody opened it up (like Will does) to check the quality?
2) Can one assume it's quality will be the same as the 12v, 100AH Watt Cycle Will recently reviewed?
--What do you think, Will? Will the internals of this 300AH mini be about the same as the 100AH Watt Cycle you recently checked out? Or could the internal assembly/components be completely different?
Thanks!
If the 100 seems trustworthy I would not hesitate to move on the 300 if it fits the need.
