have not been able to charge to 100 % yet but what im seeing so far is it needs balancing i did purchase a bench supply to work on balancingThere is a youtube video where a person tests the Wattcycle battery, and observed the same issue. So, are you able to fully charge the battery up to 14.6? or does the charge terminate at a lower voltage? Do you have a way to monitor charge voltage and current? You may have one cell with a lower voltage than the other 3. Meaning the battery is "out of balance".
book says 100amp is max continues dischargeDo you know the exact current draw and what the BMS is actually rated for? Some of the cheaper BMSs use small gauge wire, and I can see there being a voltage drop (between cells and the battery terminals) under a high load.
Guess on BMS Rs about 1 mohm, x 50A for 0.05v drop.
Misc wiring and internal connections about 2 mohms for 0.1v drop.
Which supply did you purchase?have not been able to charge to 100 % yet but what im seeing so far is it needs balancing i did purchase a bench supply to work on balancing
Would you mind post a link to it? Thanks.watched a video of will opening one and checking the quality of the build
this is one reason i purchased
purchased a cheap 0-30v 0-10 amp dc bench supply
I was referring to the bench supply you purchased... Thanks again.
Thank you!power supply
Yeah. One side of me REALLY wants the IP67 TM version with 120A BMS for a 2P setup, but wondering if I should opt for 2x or 3x IP65 mini’s whose tops can be removed with screws…for BMS replacement.Excuse the off the wall question: If one were to replace the BMS in this battery (say for example, it became fried) which BMS would the experts on the forum suggest would be a suitable replacement?
Many thanks in advance, Wiley
