Hi,
I planned to buy the Wattcycle 280 Ah Mini with Bluetooth (the updated 300Ah), when I read the FAQ:
Q: Can I use the battery while it is charging?
A: Unfortunately, WattCycle’s deep cycle LiFePO4 batteries currently do not support simultaneous charging.
I don´t follow at all, so I e-mailed the support I got the following answer:
"We don't recommend that charging and discharging at the same time. Which will shorten LiFeO4 battery's lifespan."
I mean, isn´t this the normal usage? Have a solar controller charging your batteries when you simultaneously use them? Sometimes the charge current is too low compared to the load, so you discharge, sometimes the opposite?
Do I misunderstand something, or is the BMS useless? Any comments/experiences?
Kind regards
Björn
Kind regards
Björn
