For peak efficiency and minimal degradation are 15 to 25 degrees C as you get below this efficiency tappers off but we do not experience degradation until we try to charge near and below zero degrees.
From 25 to 45 degrees c the LFP batteries will operate at maximum efficiency however the difference in the two temperatures have a great difference in degradation like a ratio of 8 to 3 at least by the EVE cell data for LF280k v3
This is part of the data specs and test procedures from the cells that I ordered I believe this would correlate to most LFP batteries check out the temperature vs cycle life at the bottom of this page.
Keep in mind this is with compression.
And cell temperatures tend to run about 5 degrees C higher when charging and discharging.
This could be the latter.
About three years ago I built a 24vt battery from 8 280ah cells from shazen. everything seemed to work fine up to about a month ago when a couple of the cells register 0v. Taking things apart I find that they are pretty swollen. I assume the cells are no longer safe to use? How might I dispose of them? Should the BMS be suspect as well?
