cho New Member Joined Oct 21, 2021 Messages 25 Oct 21, 2021 #1 My hybrid inverter is showing 27V from PV input during night. There is no amps and watts. I measure inputs on combiner box and there is 0V. Does anyone have a clue?
B Bud Martin Solar Wizard Joined Aug 27, 2020 Messages 4,843 Oct 21, 2021 #2 1. Make and model? 2. Screen shots of the display? 3. System Voltage? 4. Does it work correctly before?
T time2roll Solar Wizard Joined Mar 20, 2021 Messages 5,704 Location SoCal Oct 21, 2021 #3 Probably the default minimum voltage for that section to activate and read correctly.
cho New Member Joined Oct 21, 2021 Messages 25 Oct 22, 2021 #4 Inverter is REVO VM 3.2KW / 24V link -> https://www.solarfam.nl/revo-vm-3-2kw-24v-hybrid-inverter.html It is new inverter, installed before two weeks. I notice night PV voltage by browsing trough display menu. Display:
svetz Works in theory! Practice? That's something else Joined Sep 20, 2019 Messages 7,295 Location Key Largo Oct 22, 2021 #5 Welcome to the forums! Probably ghost voltage (aka phantom or induced voltage... basically current running in a parallel wire induces a voltage in the PV wires). Last edited: Oct 22, 2021
