Sojourner1
Itinerant
That there is what happens when all cells get overcharged and not strapped together.
The reason it didn't vent is because it had room to expand (no cell compression in the build) it would of been interesting to see how much strain on the adjoining connection.
Search is a bit Borked here. your better off using the Advanced Search function and be specific, t still takes effort & patience. I find the search quite frustrating and IMO it hurts the capability of the forum.The search on this forum is either very bad or I'm very ignorant of how to use it. I've looked for these threads and can't find them. Do you remember which forum they were in? Or do you know how to specify two required search keywords?
We can fix it. I could do a mass email or notification and have the forum down for a day.There is a way to improve search, but it means taking down the server for a while and also relying on another server for search (with the current hosting set-up). I think it might be something we do in the future, but Will was (understandably) hesitant of making the changes.
Here are some recent resources on the subject of BMS/Victron equipment interaction.Yeah the advanced search isn't much better. I tried everything I could think of to require both search words to be present in order to get a hit --- with no luck. I don't know who was in those threads so being able to specify the user doesn't help, and I'm not sure about the timeframe. How about the forum? Do you know which forum it was in?
Maybe I should head over to the Victron community forum instead.
How will I live for a day? A day without laughter is a day wasted- Charlie Chaplin Sorry not poking fun at the situation, just the taking the site down for a day. If it helps, then it should be looked into.We can fix it. I could do a mass email or notification and have the forum down for a day.
Just a caveat that I learned from making the assumption that any CANbus device can be interfaced. Apparently the words each device uses needs to be translated for the other device to understand. Maybe the open source helps but it took more knowledge than I had because my devices did not have open source.I would think that any CANbus capable BMS could be interfaced, Victron has open-sourced that software so it can be done.
not sure about this... if the battery paskc are in parallel how does the BMS know that one battery is out of spec? i seem to se the same recurring answer... " so in so says its ok so its ok." props to whomever for his work but if it does not work it does not work. so for a 16s pack it seems to work, but if it does not work for a 2p, or 3p 16s, then it does not work. yes I am dyslexic... bear with it....You need one BMS for each 48 volt pack. Two 16s BMS's.
And watch this for how to top balance.
why so much anger? which camp do you sit in???If you can't help with the OP question why not stay in a dead lead thread and spread your wisdom there. Unless you like to troll.
why victron all the time... there are other solar controllers.. Morningstar for instance other inverters as well magnum...as many other pieces. this whole forum seems like a cash cow for a couple of folks. mind you if the results were not skewed, then i would gladly pay a subscription...want a couple of bucks... I can pay pall for your test results to date.... unskewed.There is a way to improve search, but it means taking down the server for a while and also relying on another server for search (with the current hosting set-up). I think it might be something we do in the future, but Will was (understandably) hesitant of making the changes.
