The pyrotechnics seems odd in general. Per other comments I would test the voltage and polarity and turn on each independently. My guess would be one or more of the units was damaged in shipping, possibly due to a poor internal design flaw.
According to the OP he turn all of them on before he paralleled them and there were no problems only after connecting them in parallel did the issues ariseMy guess is the positive lead had a nut fall off and it is just touching the inside of the case. When it is turned on the sparks are caused by the dead short.
That really fits the positive and negative terminals being labeled wrong.According to the OP he turn all of them on before he paralleled them and there were no problems only after connecting them in parallel did the issues arise
I'm not sure how you would do that on an assembly line, this I find this idea somewhat doubtful, but I would never say never. Since I'm not there fondling it myself, ... The odd behavior if truly only when connected in parallel doesn't make a ton of sense electrically. /i'm just skeptical by nature, but what would create a backfeed type spark like that? The power switch is a soft switch that engages a relay, this is just a bizarre occurrence, I could only fathom some sort of damage to the BMS board that would cause it. I think we do not have enough good information on the whole thing.That really fits the positive and negative terminals being labeled wrong.
I would disconnect all of them and power each up and check voltage polarity at the terminals. I bet the 2nd from the bottom is wired backwards inside from the factory.
We sure dont have much!I think we do not have enough good information on the whole thing.
Yea if it was a $50 batt there would be no debate about opening it up but these aren't cheapThe safest bet is to separate them and test the output at the terminals. If that passes I wouldn't do anything else with them until I contacted the manufacturer. Going further risk warranty problems.
Please post the cause of the failure when known we are a bunch of curious individuals all trying desperately to get the right answerThis looks like a short somewhere, I will assist you in getting after sales support as soon as possible!
Good catchIn the thread pics and the vid the RED pos terminals are on the Right side of the packs,
But on the Ecoworthy website the packs shown have the RED pos terminals on the LEFT SIDE of the packs...
In fact, I don't think I have ever seen a server rack pack with pos on the right before.
except I think I was mistaken - the battery on their site with the Red pos on left isn't a server rack pack, just a case battery.Good catch
Yeah we really need to know. Can't do wait to find out
How are the lugs connected to the terminal?
It looks like the lugs are 'reversed', thus facing down. That leaves only a very minimal gap between the lug and the 4 screws which hold the terminal itself Maybe even only insulated by the heatshrink and/or a very tiny gap.
Altough the video isn't very clear, it looks like the point of origin of the spark is one of the screws holding the terminal to the casde... if the positive also has this (or on any other battery) that basicly makes the whole stack/cases positive... (even with the BMS off since the BMS only controls the negative)
Switching on a BMS will instant create a short between the chassis and the lug of the powered-on battery in that case.....
Measure to see if there is any connection between positive and the chassis.
The negative and positive screws securing the terminals are bonded. Just tested it on mine. Connect straight to the case. Very common configurationHow are the lugs connected to the terminal?
Seplos Mason has positive terminal on the right. Negative to the left of it.In the thread pics and the vid the RED pos terminals are on the Right side of the packs,
Actually, on the Seplos website they show Mason product photos where the red terminals are randomly on the left or on the right, depending on the Mason capacity size. But in all cases, the terminals on the left are positive and on the right are negative, i.e. on some products they appear to be using red terminals as negative and black terminals as positive, with no consistency. Why would they do that?Seplos Mason has positive terminal on the right. Negative to the left of it.
No way they have mixed the terminals. Placement is one thing, using red/black backwards ridiculous.......isn't it ???Actually, on the Seplos website they show Mason product photos where the red terminals are randomly on the left or on the right, depending on the Mason capacity size. But in all cases, the terminals on the left are positive and on the right are negative, i.e. on some products they appear to be using red terminals as negative and black terminals as positive, with no consistency. Why would they do that?
