The ai starts down that road I'll nip that in the bud FAST.
At that point, it'll be too late. Just hope it doesn't learn how to self replicate.The ai starts down that road I'll nip that in the bud FAST.
We are the batteries...Way off topic but I am ready to get away from melting wires!
The latest trend is to connect all the AI facilities directly to nuclear reactors or even put it under the facility.
Even the Si-Fi never though of this. Nobody would have ever believed we were so fricken stupid.
I want to have a couple mile long transmission lines and batteries outside the building that we can take out if necessary.
Doppelgänger. Be careful out there!5. It will let the wife in the house or the workshop when her fingerprints won't work the lock keeping me from having to go do it. Never have figured out why I have to re-add her fingerprints to the scanners.
you make it so that it is insanely obvious that something will not fit correctly (square peg in a round hole for example),
I have that style on my gokwh 5kwh rack mount. I hate them because I can't put a decent 1/0 lugs on them I think biggest maybe 4awg?
Terminal snob LOLView attachment 273908
Countersunk screws on SOK 48V batteries and two terminals so you never have to flip terminals to make room for enough cables to fit.
There are snobs for everything on this forum!Terminal snob LOL
Shouldn't the case be floating? If one cable shorted to the terminal mounting screw it would not spark but if 2 opposite polarity cable lugs shorted to terminal mounting screws it would spark. Also could be a short inside one of the cases which shouldn't be there.Solved:
The cable was shorting on the screws on the front terminals. Everything working now.
Please do as now I have new anxiety unlockedI actually filmed this issue two weeks ago and figured no one would care so took it out of my videomight need to dig up that clip and post it now haha
Looks like one could design and 3D print different bits of plastic, to either replace that plastic that the terminal screws are screwed into, or go on top of the screws but under the wire (if the plastic can't be removed)
Just realized my 50Ah came with terminal covers, they slide on using the slot in the terminal mount....however with the slot gap on the rear of the cover you could still run into that issue with lugs reversed and contacting. Also doesn't fit properly when using double lugs to daisy chain which is understandable.Looks like one could design and 3D print different bits of plastic, to either replace that plastic that the terminal screws are screwed into, or go on top of the screws but under the wire (if the plastic can't be removed)
Just received terminal posts from aliexpress for a battery build and after seeing this chats fire works video.
Posts seem decent enough, and stand off from post end/ lug to fixing screws is 10mm and as above have cover caps.
Belt and braces, I cut 4no. 1mm insulation board to go over posts on both sides to insulate fixing screws.
Nice and easy fix if anyone wants to ensure no fire works to fixing screws.
View attachment 274175View attachment 274176View attachment 274177
Just zero need to mount them that way imo, just offset them and have them facing outwards...Anyone putting lugs on this way needs to check for clearance to metal, allowing for lug movement.View attachment 274183
If the copper lug is the main cable to the inverter wouldn't you want that on the bottom?Just zero need to mount them that way imo, just offset them and have them facing outwards...
Yeah I just slapped them together without consideration, in this case this pair of 50Ah goes to a power in, and there's three other 100Ah equivalent batteries also connected so currents are very low, generally 25-50A.If the copper lug is the main cable to the inverter wouldn't you want that on the bottom?
