immortl
With regard to wet stacking a diesel generator - something like a Kubota Lowboy II 11kw or 14kw generator, my understanding is the engine runs at a constant 3600rpm on these, or am I wrong on this point? if I'm wrong the premise of my question is incorrect. Is not constantly running at 3600 rpm enough to keep them from wet stacking, regardless of the electrical load from the generator portion? Based on my diesel pickup truck experiences, unless I've been doing it wrong, one kicks up the idle speed via a controller to prevent wet stacking when idling for an extended period of time. The high idle raises exhaust gas temps despite not much of an actual load on the engine and the higher temps indicated by this is enough to burn the fuel and prevent wet stacking. If my understanding is correct and the Kubota runs at a steady 3600 rpm, ought that be enough to prevent wet stacking regardless of the actual electrical load?
As I'm planning and building out my off grid solar system, I'm looking forward a bit and want to put in a decent diesel generator to primarily charge batteries and possibly also simultaneously feed the AC in on a pair of Victron Quattro 10ks. For right now I have a predator 7000 running watt non inverter gas generator that came with the property. This is sufficient to run 1 chargeverter. 11 or 14kw is likely overkill for my current electric needs today, but as I build a proper house, shop, greenhouse, assorted outbuildings etc... for the future I am thinking 11 or 14kw diesel would be sufficient to run 2 (11kw) or 3 (14kw) chargeverters and simultaneously feed some minor loads. Could end up being undersized but seems like a happy medium to start with. Starting battery storage will be 64kwh via 4 Midnite MNPowerflo16s. I foresee at least doubling if not tripling that over the next year or two. Winter tends to be fairly overcast where I am at in mountains of Western Montana.
Thanks,
Joe
Thanks,
Joe
