Hi
Based on some tests I did during the last weeks with our 38' Beneteau sailboat, I remarked two main things:
-Cruiser sailboat are slow.
-Cruising at low speed require really low power (I've tested 1 kW at 3 knot).
Clearly, instead of beating to windward at an average of 4-5 knot, why not simply go in strait line with a solar Catamaran?
That our conclusion and here is a potential plan:
40-45 ft Catamaran without sails and mast, add 10-12 kW of solar, add 120-170 kWh of battery and there you go.
Everything in 48V to access typical component's.
Here two good examples:
I am a retired educator married to a retired chemist/engineer/educator. We will be living aboard our solar electric catamaran for as long as possible.
lisamarchi.com
I've built a solar catamaran out of a 2000 Gemini 105M sailing cat. Some basic specs:
- 2x ePropulsion Navy 6.0 motors, 6000w each max.
- 16x BlueSun Bifacial 575w solar panels, max output 9200w.
- 2x EG4 100amp MPPT solar charge controllers
- 4x 48v 160ah LiFePO4 batteries
- 2x EG4 5000w shore chargers 120v/240v
- 5000w Inverter
- Starlink Internet
- Openplotter navigation with AIS
I've got two independent setups, motor, battery, chargers and panels. No fossil fuels of any kind on the boat.
Sweet spot is 5.3 knots @ 3200w, max speed is around 7.3 knots @12,000w. You pay dearly for that...
Questions about design:
1-Solar panel qty: I can start with 400W to 600W solar panels and there is place for 16-30 panel on a frame. I think it's a good plan to have a space in the center to let exit the wind and also to have access to clean the panel (see pictures).
2-MPPT qty: From 2 MPPT up to 12 MPPT (or more) what can be the sweet spot? It highly depend of the panels and I thought about a configuration of 3 panels with around 45V Voc for each Victron 150/35 MPPT... or 12 Victron 100/20 for 24 panels or 2 EG4 MPPT for 20 panels or even one Boost MPPT for each panel... There is many choice. What is a the best one?
3-Lightning: What to do about lightning with this kind of giant aluminum antenna over the boat?
4-Power requirement: Based on searches and tests, this kind of 15 000 - 20 000 lbs boat will cruise at 4 to 7 knot with as low than 3-4 kW and up to 10-20 kW. So the power requirement is low. I will still be able to output 40-50 kW, but this is not cruising speed power requirement.
5-Range expect: 100 to 200 nautical miles, not more. Still 100 miles can take 24 hours
6-Expect production: Based on 10kW installed and no shade, I think this will produce between 25 kWh to 60 kWh per day. Right? Let say in Caribbean. Flat orientation is not awesome in winter, but is this realistic?
Below is a rough 3D of a 40' boat with 20 panels of 500W.
Please share your inputs!
