Xtinabritannica
- Jun 3, 2022
- 8
I'm clearly missing something. My EG4 battery and inverter are running fine, but the inverter will not acknowledge the PV voltage.
I started with one panel only, mostly because I'm a tiny thing and I need help to lift them ?. But even one panel out of the three has more voltage than the battery, so I don't believe that's the issue.
I checked:
SPECS/Info:
I checked:
- The PV connections on both ends
- Made sure the MC4 connectors on the panel weren't installed backwards at the factory
- The voltage on both ends reads 62.8 V, so there's no drop
- The settings on the inverter for priority, and amps
SPECS/Info:
- 32ft Keystone 2003 Travel Trailer (will be stationary for a while)
- Parallax 7300 120VAC -> 12V Converter already installed with circuit board
- EG4-LifePower4 Lithium Battery | 48V 100AH
- EG4 3kW Off-Grid Inverter | 3000EHV-48 | 3000W Output | 5000W PV Input | 500 VOC Input
- 3x 345W SunPower in Series
- Rated Voltage (Vmpp) 57.3 V
- Rated Current (Impp) 6.02 A
- Open-Circuit Voltage (Voc) 68.2 V
- 12v 27DC Marine Battery
