I got mine for about that,($160.00 for the box and about $50.00 for the BMS,on/off and screen)for 24 volt boxes. I also had Amy@Luyuan make me some custom dual 12volt 560ah boxes. Two 12 volt 280ah batteries in the same box, each with its own 200amp breaker, 200amp Jk BMS with on/off and screen.
Sorry, here is a link. Start a chat or email with Amy the owner, she has taken care of quite a few people on the forum, and the only complaint I have seen had to do with the time difference and turn around text /email. If you are interested in the double box tell her Stacey referred you.
size 31 battery box
Size 31 box, Outside Dimensions: (LxWxH) 18-7/8” x 9-1/4” x 10-1/4”,
Added pass thru terminals, internal 150A ANL fuse, Radio B BMS (same as overkill solar)
Padded the floor and some of the sides with antivibration padding
Between the cells I used insulating "electronic fish" paper
Gap on one end was filled with a cut up yoga block
