What battery charger for a 14s lg chempack
Trev2323
OK i am learning as I am Going I built a 14s 48v Lithium LG Chempack battery and I have a Daly BMS. I was planning on using my Growatt Solar inverter to wake up my DALY BMS. BUTTTTT The Daly BMS has to be woken up so the growatt can read 48 v and wake up the Growatt
WHAT charger should I buy for a LG Chem pack 14s 48v?
I had a similar issue, I purchased a 5amp varible voltage >48V charger from Amazon. You only need to give it a small shot of amps and it wakes up. Then you can continue charging from solar.
