BigIslandRyan
- Apr 16, 2020
- 35
I just bought a small 6cubic feet solar refrigerator (12/24v) that I need to build a temporary rig for. It pulls 53watts. Will be using for 2 months in Dallas where we get a fair amount of sun in the summer.
My plan is to run (2) 240watt poly panels (used ones from SanTan solar, already acquired) in series
A 100ah SOK battery (12 volt) - already acquired
30 amp EPEVER MPPT Solar Charge Controller - already acquired
Since I am only powering the fridge and no other loads, my plan was to just connect the fridge directly to the load connections on the charge controller, with no dc fuse block and no positive or negative busses. Plug the battery terminal wires into the controller, plug the panels into the controller, and let the controller do the thinking for me. And there is no inverter in this scenario either.
Will this work? I verified the voltages and amperages are within needed ranges for the controller. Is there a critical in line fuse or breaker needed somewhere? If so, where? Am I over simplifying this?
