please nit pic this apart for me . and catch what i did not. 4 agm batterys 100amp hour . in series for 48v.. wire is 6 gage from a golf cart. the copper plates are old copper pipe flatten.. and will add vent going outside.
no that is not what i want to happen.. so wood box not good? its what i had..Is the photo in your avatar the result of using this battery configuration and the wooden holder?
wood can be bad if it touches the terminals depending on its moisture content. Another member on here had a fire caused by a plywood cover on their battery box.no that is what i want to not happen.. so wood box not good? its what i had..
several rooms in a house. and building up battery bank as i can afford and being they are 100 amp hour battery . i was thinking 80 amp fuse.. and got a few replies to make i see gotta ya no wood spacers i do have old glass ones from the knob and tube wiring in this old house.. i will go find them. also made a few more plates for the bus bars. to make them heavier .Without more information it’s impossible to say. For example :
What are you powering with this and what is the maximum amp draw ?
What size is your fuse ??
good to know .. i will go glass . if i can find the ones i have. thankswood can be bad if it touches the terminals depending on its moisture content. Another member on here had a fire caused by a plywood cover on their battery box.
If you take special care to avoid this or use an isulative material I'm sure all would be fine.
it will be 80 amp.. the fuse should protect the battery and the wire . i am just learning thisWithout more information it’s impossible to say. For example :
i will think on this i see the problem .. and it is me. plywood cover.. thinkingwood can be bad if it touches the terminals depending on its moisture content. Another member on here had a fire caused by a plywood cover on their battery box.
Looking at the photo in the 2nd post, you would do better with using regular battery cable. Forget the copper pipe. If it is hard copper, it will crack. You would need Type K or L annealled, sold in a roll. Nothing used as the inside will be coated with green. Copper pipe is not the answer.please nit pic this apart for me . and catch what i did not. 4 agm batterys 100amp hour . in series for 48v.. wire is 6 gage from a golf cart. the copper plates are old copper pipe flatten.. and will add vent going outside.
i see the need in having a camera for heatWell 6 gauge wire won’t do. See here :
Part 1: Choosing the Correct Wire Size for a DC Circuit - Blue Sea Systems
Engineering high quality marine electrical components for safety, reliability and performancewww.bluesea.com
If the wood is dry and your busbars are up to the task I don’t see an issue there. Lots of folks use wood enclosures.
Once under load all of your busbars and crimps should remain cool to the touch.
ok i need at least 4 gage wire or 2 would be better.. thanks good callWell 6 gauge wire won’t do. See here :
How many feet? Longer cable results in voltage drop.ok i need at least 4 gage wire or 2 would be better.. thanks good call
not buying the imager , grin. i just want one so bad.. no this will not be running this month. next month two breaker boxs for the ac and dc breakers and welding 4 gage wire.. next month.. dreamsInstead of buying a thermal imager, use the money to buy some copper flat stock or some large battery cable, a crimper and some lugs.
less than 3 feet so thinking 4 gage for now and when i upgrade the battery bank then with 2 gage..How many feet? Longer cable results in voltage drop.
