so, are the following components a good start to store minimal power?
2=265w panels (I have a total of 6 but don't think i would need all of them to power up 2 batteries at a time)
60A MPPT SCC
2000w 24v inverter
2=24v lifep04 Li Time batteries
I would say no. I'd expect 530W would be good enough for a 12V system, but I'd say a minimum of four of those panels for a 24V system. Batteries perform best when charged at a certain rate. Of course there are exceptions, but here are some VERY broad guidelines for different battery chemistries.
traditional flooded lead-acid: 1/10th to 1/8th of C
sealed AGM: 1/8th to 1/5th of C
Li: 1/5th to 1/4th of C.
So, in your case, you have two 100Ah strings of Li batteries at 24V. That means YOUR "C" is 200Ah at 24V. Looking at the math, a charge rate between 1/5th and 1/4th means...200Ah/5 = 40A to 200Ah/4 = 50A. So, for your particular battery bank, it most likely will be most happy getting 40-50amp of charging. The 60A controller would be fine for that.
Now, if you assume the minimum charging voltage the batteries will see is 25V, it becomes a simple math problem. 40A X 25V = 1000W of panels 50A is 1250W. So really, at least doubling the number of panels you want is the proper way to go.
There's a second way to look at how much solar you need to have, and that is to base it on what your loads are. A good rule-of-thumb that I've used a long time is use the 1.5X to 2X rule. That is for every watt of load you want to support, have at least 1.5X that sized load in solar panels. It's not carved in stone, but over the years it has worked very well for me in real-world applications.
Let's say you want to run a 1 Liter hot water kettle. It consumes 1000W. Using the 1.5X rule, you should have at least 1500W of solar. So, either scale your solar to your battery, or scale your solar to your load, but both are significantly higher than just 530W.
Now, depending on which controller you choose, you have the choice of wiring four panels as either 2S2P, or as a single 4S1P string. The 6415 controller would be able to handle at least three in series, but for four, you need the 6420 controller.
Now, finally, one more way of determining solar is based on your sunhours (sh). That is, the amount of time per day you can expect to get FULL POWER out of your array. If you are located in South Carolina at about 33-34 degrees North, I'd suggest you'll get about 3 sh in December, and maybe 6sh in June, on clear sunny days. You simply multiply your sunhours by your watts of panels to determine how many watthours (or kWh) of power you can make. So, for example, with four panels totaling 1060W, you could make 1060 X 3sh = 3180Wh in December, or ~6.4kWh in June. On cloudy days, with rain, don't expect to get more than maybe 0.5sh per day. That is NOT going to keep a refrigerator running.
