What data do the Eg4 server rack batteries share with a Cerbo?
Dooug
Ordering 3 batteries and a new multiplus this month and and am wondering how much information the cerbo can interpret when
connected to a Eg4 server rack. If not only basic data passes between the two I am inclined to go to the LL batteries that have a screen for easy access to data.
It is my understanding that with a laptop, all data can be viewed with all the Eg4 server rack batteries. Hoped to get some useful info over the VRM and avoid constantly hook up the laptop in the first few months as things settle in.
You can run closed loop or open loop via CAN bus.
I choose to run open loop and let my Victron SmartShunt determine SoC.
Nevertheless, I log the info from the batteries and see it all in VRM.
When you hit 100% SoC, you usually get an overvoltage alarm which is annoying.
Other than that it works well. I have EG4-LL v1s.
Should be the same for v2s and LL-s.
LifePower may be different, not sure.
That is great to see. I'm guessing each battery has its own set of screens?
Sadly no, everything is aggregated into a single battery.
In my case, the three batteries show up as 300Ah.
However, it will tell you how many “modules” are online/offline.
And you cannot get individual battery cell voltages, you need the built-in battery screen for that.
Just min/max cell voltage over all three batteries.
Note my lowest and highest voltage cells are from different “packs”.
“pack” = “module” = single rackmount battery
Ah ok. That is unfortunate, but still helpful information.
I wonder if there is another option for easy access, this does make we want to just spend the extra $100 a battery for the screens. It does say "LCD" below the USB port on the new V2 lifepower. But the manual states that port as "reserved"
Can’t help you on Lifepower, hopefully someone can enlighten us.
If I were buying today, it would be LL-S for the screen and UL.
If you get things working and set up ssh command line into the Cerbo, run
dbus-spy
and you will see all data going into the Cerbo via dbus, perhaps some data not displayed in the GUI.
Good idea!
Pretty much the same info though.
I left out the Diagnostics which were all blank. Scroll right for values.
Code:
Alarms/CellImbalance        0
Alarms/ChargeBlocked        0
Alarms/DischargeBlocked        0
Alarms/HighChargeCurrent        0
Alarms/HighChargeTemperature        0
Alarms/HighDischargeCurrent        0
Alarms/HighTemperature        0
Alarms/HighVoltage        0
Alarms/InternalFailure        0
Alarms/LowChargeTemperature        0
Alarms/LowTemperature        0
Alarms/LowVoltage        0
Capacity        -
Connected        1
ConnectionInformation        -
CustomName        .Battery Rack EG4-LL v1
Dc/0/Current        1
Dc/0/Power        53
Dc/0/Temperature        29
Dc/0/Voltage        53.45
DeviceInstance        512
Family        -
FirmwareVersion        22017
Id        -
Info/BatteryLowVoltage        45
Info/ChargeRequest        -
Info/FullChargeRequest        -
Info/MaxChargeCurrent        150
Info/MaxChargeVoltage        56
Info/MaxDischargeCurrent        300
InstalledCapacity        300
Manufacturer        EG4-LL
Mgmt/Connection        CAN-bus
Mgmt/ProcessName        can-bus-bms
Mgmt/ProcessVersion        v0.59
ProductId        45063
ProductName        EG4-LL
Redetect        0
Sense/Current        -
Sense/Soc        -
Sense/Temperature        -
Sense/Voltage        -
Serial        -
Soc        91
Soh        100
System/MaxCellTemperature        29
System/MaxCellVoltage        3.343
System/MaxTemperatureCellId        P01-2
System/MaxVoltageCellId        P03-01
System/MinCellTemperature        27
System/MinCellVoltage        3.341
System/MinTemperatureCellId        P03-6
System/MinVoltageCellId        P01-09
System/NrOfModulesBlockingCharge        0
System/NrOfModulesBlockingDischarge        0
System/NrOfModulesOffline        0
System/NrOfModulesOnline        3
