bernadinenewland@hotmail.
- Mar 12, 2021
- 3
You want an ac2dc charger to charge your battery bank via generator.We are beginners and have watched dozens of videos and read so much our heads are spinning. I have searched this site and still am not sure.
We have a PREDATOR
9000 Watt Max Starting Extra Long Life Gas Powered Generator. We would like to use it to charge our battery bank and maybe have some solar. We are considering Lithium Iron batteries and need to know how to hook up the generator to the charge controller, which charge controller is best for this or does it matter, and what other things we need to consider. Thanks.
Ok we are thinking of one 200 amp lithium iron battery for now. We may go with two of them but is there any danger of charging too fast? I'm sorry for all the questions but how long would it take to charge one battery or if get them two batteries? Do the Converters or inverters have fuses in them? Or do we need to purchase them separately?You need an AC-DC converter. Most of those come with a plug on the end of the cord that allows you to plug into a standard 15 amp outlet.
You'll size the converter based on your battery bank and how fast you want to charge that bank. The generator should easily handle most 120Vac converters.
Thank you so much. We are working hard to understand all this. your advice is really appreciated.You need to check the specifications for your batteries to know how many amps they can be charged at. The general number is that you charge at no more than half the Ah rating. So a 200Ah LiFePO4 battery could be charged at .5C or 100 amps.
A 200 Ah battery, at a low state of charge, would take about two hours to charge when charge at 100 amps. AC-DC converters rated that high are not common, but do exist.
A converter usually has fuses, but those are to protect the converter. A breaker or fuse on the wire between the converter and the common bus bar (or the battery) is there to protect the wire.
I see this thread is a few months old but, it seems I can only find ac to dc chargers up to about to 50 amps DC, that can still plug in to a standard 110v outlet. Above that rating, they need 20+ amps of AC and thus heavier wiring, breakers and plugs
