sawmonandnatalie
Hi all,
We have created our initial draft of our electrical wiring for our class C motorhome ( 1986 Ford E-350 V8 460 CI with a 1985 Vanguard Coach ). Here is how it looks like:
We are going to have the solar panels in a 2S2P config and the batteries will be just a 4S for a total of 12V.
We have a few questions regarding the fuse and breaker bar ratings.
Here are some specs for the Renogy 100W Panels:
and the specs for the MPPT charge controller:
- What breaker bar rating do we need to use before and after MPPT solar charge controller (between solar panels and MPPT, and between MPPT and positive bus bar)?
- What fuse rating do we need to pick for the main positive line to the DC fuse box? Is this rating for the max amp that the DC fuse box can potentially handle? or should we have to calculate it for only the sum of fuses used in the DC fuse box? We are not sure on the full list of DC components that we will be using.
- How do we calculate the fuse rating from the positive bus bar to the invertor? We are planning to use a 2000 or 2200 Watt inverter like the GIANDEL 2200W Pure Sine Wave
- What fuse rating do we need to use for our 4 cell LifePO battery? In our diagram, we might have an extra fuse there. One fuse in the battery grayed boundary and one fuse on the bus bar just before the red switch.
- What fuse rating do we need for the Battery Converter/Charger? We are not sure what battery charger we would get. Do you have any suggestions? We have been looking at this Progressive Dynamics PD9160ALV 12V Lithium Ion Battery Converter/Charger - 60 Amp so far.
- If we decide to have the option to charge the battery pack by the alternator, what fuse rating should we use for it on the positive bus bar?
- What switch rating do we need to get to disconnect the battery from the load/positive bus bar?
- How about the shunt rating for the system?
- [Purchased] Tracer4215BN - EPEVER 40A MPPT Solar Charge Controller 150V PV Input 12V 24V auto Work
- [Purchased] 4pcs EVE 3.2V 280AH New Version Genuine Grade A Lifepo4 Battery Cells Fully Matched for Solar System EV RV
- [Purchased] Smart 4S cells 12V 120A 1000A Lifepo4 li-ion Lithium battery protection board W balance High Current BMS
- 4 x Renogy 100 Watt 12 Volt Monocrystalline Solar Panel (Compact Design)
- Blue Sea Systems ST Blade ATO/ATC Fuse Blocks
- GIANDEL 2200W Pure Sine Wave Power Inverter 12V DC to 120V AC with 20A Solar Charge Control and Remote Control
- Progressive Dynamics PD9160ALV 12V Lithium Ion Battery Converter/Charger - 60 Amp
RNG-100D-SS
100W Monocrystalline Solar Panel
P_max at STC = 100W
V_mp = 17.9 V
I_mp = 5.72 A
V_oc = 21.6 V
I_sc = 6.24 A
Max System Volt = 600 VDC UL
Max Series Fuse Rating = 15 A
Cell Efficiency = 21%
P_max at -45ºC = 116.1 W
V_oc at -45ºC = 26.5896 VDC
I_sc at 60ºC = 6.3492 A
[ 2S2P ]
V_oc = 54.0 VDC
I_sc = 12.8 A
P_max = 464.4 W464.4 W = 14.4 V x 32.25 A
Tracer 4215BN 12/24V
Rated Charge Current 40A
Rated Discharge Current 20A
Max PV Voltage 138 V or 150 V
