What gauge wire between the PV & the controller?
KA1J
I have four 400 watt Q cell panels, the information on these is here:
https://cdn.myced.com/images/Products/ZZ0000/ZZ3048/00000/ZZ304800120_DS.pdf
Voc - 45.30
Isc - 11.14
Vmpp - 37.13
Impp - 10.77
I am planning on running these in series and there will be a roughly 50' run of wires from the Panels to the controller.
Looking at the voltage drop calculator I came up with the info in the following link.
https://www.calculator.net/voltage-...ceunit=feet&amperes=10.77&x=29&y=11&ctype=nec
I'm thinking of using a pair of 10 gauge wires running 50' to the controller. The calculator says there would be a .71% voltage drop, not that much but I had to guess at the Power Factor (PF), I don't know where to generate that data.
Then I thought about paralleling two and running those pairs in series which made a voltage drop of 2.83% as seen below. It looks like all things equal I should just stick with running all 4 PV in series.
https://www.calculator.net/voltage-...ceunit=feet&amperes=21.54&x=80&y=25&ctype=nec
My main question is with these 4 panels in series, will 10 gauge should be to the controller?
My other question is if I were to series parallel the PV, it would help mitigate shading on one pair of panels, but would 10 gauge still be OK for a 50' run given the four panels I have?
Thanks.
10 should be fine either way, I’d run 8 in case I decide more solar is needed. If shading could hit one or more panels, 2S2P would be better, if the voltage gets hit enough to charge reliably.
Thank you for the reply. I can't get more panels at this location, no more room unless I put it on the house & I'm selling soon and I'll have a more robust setup at that time. For now these 4 panels will have to do & they do get shade. I can do 2S2P and that might be better because of that shade, it's just the amps will be a bigger factor so I've been paying more attention to going for volts & trying for lighter wire.
Good to know the 10 will be OK either way.
Tnx.
Don't forget that your solar charge controller will need to be capable of handling up to 200 volts on the input side. If you're located in a cold climate area, those panels could produce close to 200 volts.
10 gauge wire should work. Make sure you're using actual PV wire that is UL 4703 rated.
Thanks for the reply. Yes, I chose the Victron 250/100 which is overkill but will allow any reasonable flexibility I will likely encounter.
The wire I have has silicone insulation, 10Ga 1050 strand, tinned copper wire, 600V rated, 200C to -60C .
Yes, but is it UL 4703 rated? I can't find much information out there that says that silicone insulated wire is acceptable for rooftop/PV implementation.
I'd like to have the panels on the roof but these are being mounted on a rack at the far side of the garden on a wood frame. I'll be running these buried to the house in PVC. I'm not hooking into the grid, I'll be running my Ham Radio equipment & maybe a refrigerator from solar. I'll plug all of it into the inverter. It's mostly an emergency power source like a generator, so according to the town hall, there's no permit needed.
Unless I'm missing something, Power Factor (PF) is only relevant to AC circuits and can be ignored.
As for the cable, for a given current, the voltage drop is a constant regardless of system voltage.
Compare 10V @10A vs 100V @10A on the same cable with 1V drop.
the 10V system will give you 9V - 10% loss
the 100V system will give you 99V - 1% loss
This sounds like a temporary setup so regular 14AWG is perfectly fine.
It is such an American thing to oversize stuff. Who said 8AWG lol
Result​
Voltage drop: 3.35
Voltage drop percentage: 1.85%
Voltage at the end: 177.41
Remember this is max drop under perfect output conditions.
