Inq720
Odysseus, expert on the Siren's call
I'm not looking for the obvious answer. So, please bear with me...
There is the easy (obvious) answer. A very large battery bank and a equally appropriate (huge) solar panel array in a stationary setting with clear view to the sky... say in Arizona. The batteries are deeply discharged through the night. The answer is obviously: one cycle per day.
Why Asking?
I'm reading the threads about improving battery life:
The tests are very structured, very consistent and to 100% discharge and 1C.
My normal conditions are very different. Before I go to all the trouble of using threaded rod, springs, that I don't have room for, I'd like to get an understanding of what might constitute a cycle.
In my tiny system... a single 280 Ah, 4S battery and 200 watts of solar panels on a boat. My largest draw (ever) will be less than 0.5C. Most of the time, I'll be below 0.1C. Charging might be very irregular - shading of the panels, clouds, etc. Say I have small loads, and have good solar - thus, I'm charging. I go to a heavy load for thirty minutes or clouds go over - thus, I'm discharging. Is this a cycle? If so, I might have hundreds of cycles in a day.
What is the mechanism for the deterioration of capacity? I'm reading about LFP having memory (2/3rds down in this article). Does having many micro-cycles make things worse or better than the consistent, 100% discharge tests above?
Thanks.
Why Asking?
- https://diysolarforum.com/threads/best-practice-for-300kgf-‘fixture’-280ah-cells.16101/
- https://diysolarforum.com/threads/e...e-clamped-tight-or-spaced-for-expansion.7892/
Thanks.
