Starfish Prime
- Oct 25, 2019
- 15
I've been off grid in 800sf farm house with a Schneider Conext SW4048. I have never liked the thing, its a cantankerous beast.
They tell you the "4048" stands for 40 amps and 48 volts. The 48 volt part is correct but the 40 amps is max.
Sticker on unit says max 24 amps continuous on 120 side and 24 amps for the battery charger. 3800 watts continuous.
It's supplemented by a WEN dual fuel 4200 watt inverter generator. I don't have any high inductive loads either. Gas heat and inverter fridge, also hi SEER mini-splits blah blah blah
Largest issue is trying to utilize 30 amps and get it to share between charger and supply side. I'm sure its a programming issue but even the tech guys couldn't nail it down.
Anywhoos. I'm looking to replace it and considering Victron. I have to supply 240 split phase to the service panel just like you would from the meter.
Not grid tied so no fear of back feeding.
Anyone have an experience they'd like to share with supplying 240 split phase to the panel? In particular: the Victron products
I have 3K watts of PV,
10.2 KWH of LiFEPo4 EG4's
Midnite solar classic 250
Thanks my new friends
Starfish Prime
Starfish Prime
