jbatx
I make stuff with things
The JBD BMSs have value called "balance capacity". This value can be pulled off the device using the Arduino lib. I have three JBD (Overkill) bms's on three batteries and the values I get from them are
"45" from both 100ah batteries using 16S 100amp 48v units
"120" from the 230ah battery using a 16S 100amp 48v unit
The Overkill arduino lib README has only this to say about this parameter "Balance capacity in amp-hours". ...OK, but what does that actually mean and how is it calculated?
I don't really understand what this value represents. Anyone?
For reference, the cell voltage delta is 4mv and 7mv for the two 100ah batteries and 12mv for the 230ah. Current SOC is is 46% for both 100ah batteries and 53% for the 230ah.
