I purchased 4 cells from Ezealco back in February. After 6 or 8 weeks of ownership, I top balanced them to 3.65V and installed the battery in my camper with an Overkill BMS and a 30 amp Victron DC to DC charger. At rest, there’s generally a 6mV-9mV spread between the lowest and highest cells. However, when I charge the battery, two of my cells get up to 3.5V before my other two can even reach 3.4V. The cell that hits 3.5V first will trigger the over volt warning on the BMS and charging stops so the cells never re-balance.
I’m not sure if I have mismatched cells and I need to order new ones or if I need to rebalance or something else.
Here are some screen shots for some data points. The first is after sitting overnight before driving
This is after charging during a drive
This is after sittting overnight after the drive above
And this is after driving for about 9 mins
